MikeRi24
- July 30, 2007
- Amherst, NY
- 2002 XLT
Ok, i just dropped my truck (02 XLT 4.6) off at the dealer for an issue which i thought was with the transmission. under hard acceleration under load (like going up a thruway on ramp), the truck would buck and jerk in the driveline. I thought it was the transmission slipping because i know these things are known for bad transmissions.
So, the "shop foreman" at the Ford dealer went for a test drive with me. he drive it, felt the problem and said "its the transfer case, which is slipping and caused by your tires." I recently just put new tires on the truck, which are Interco TruXs MTs. They are a LITTLE bigger than the stock size, but not by much, they are 235/85/16
The "shop foreman" proceeded to lecture me on how these trucks are very very sensitive to tire circumference blah blah blah and that if the circumference is off by even 1/2" then it will effect the the transfer case and if you blow out one tire you have to always buy 4 new tires otherwise it will be thrown off again blah blah blah. So he gets it to replicate the problem with me in the truck on a test drive, and in the middle of it doing it, he puts it in 4 wheel and it stops.
now, my question is, if the tires were causing the AWD to be messed up like this, wouldnt it do this ALL OF THE TIME and not just under hard acceleration under heavy load? thanks in advance for the help. I've been fighting with this dealer for a while tog et a bunch of issues resolved. Don't get me wrong, I love my Explorer, but with all of the problems I have had with it thus far, I want to get rid of it.
