loud04explorer
- July 16, 2009
- Cincinnati, Ohio
- 2004 Explorer Limited
Ok so for starters my rear driver side wheel had a ton of play in it, so we narrowed it down to the hub. Replaced the hub assembly now there's not as much play but if i grab each side of the tire and push/pull there is some play in it still, and periodically after taking off from a stop there's a nasty "screeching" sound coming from it. Almost like really bad grinding from the brakes but more higher pitched. Does anybody have any ideas of what i should look for? Been down to 1 vehicle this week and it's been a huge burden, i was hoping the new hub assembly would've did the trick but that doesn't seem to be the only problem.
