koda2000
- September 2, 2011
- x
Ok so I took apart and cleaned the contacts on the power distribution box and I swapped the W.A.C relay with the fuel pump relay ..... What is the w.a.c anyway?
Bent out prongs on relay and it fits much tighter and doesn't feel loose any more.I also tried the key a few times and got a prime every time.
Its too late to fire it up, but tomorrow I'll do a fuel pressure test and a drive and report back.
Are you talking the A/C Wide Open Throttle Relay? If so, It cuts out the A/C for max engine power if you floor it.
