its finally done (almost) | Ford Explorer Forums
liquidx9
Houston, TX (home) Ripon, WI (school)
5.0 AWD 97 Limited
well, the mids and the highs are finally in. thanks to drew for all his help.
audiobahn components front and back. the front tweeters are mounted on the highest portion of the door (right above the side view mirror controls), and the rear tweeters are mount beside the midbass drivers in the rear. for all the naysayers about tweeters in the rear, they are a pain in the @ss, but definatly worth it, sounds just as good in the back as it does up front.
the components are getting their juice from a depth charge D4004 (i think thats the model number), the exact same amplifier as the memphis MClass 116-MC3004 amp that puts out the same numbers (115x4 at 4 ohms, with .03 THD). from my many trips to the stereo store to get parts, there is no cap, and there will likely never be a cap (even when the subs go in), i can explain the reasoning behind this later if anyones interested.
head unit is a clarion dxz925, and i cant even begin to get into how it lets you tweak your system, for those of you who cant tweak enough, this, or the 2003 model (dxz935... same exact model, little darker paint on the aluminum though) is the way you should be going.
all in all, i didnt ask too many questions, but let this be advice for the newbies, i searched, a lot, and my answers were there. so thank you to everyone who helped me without knowing, and especially thanks to drew.... and dave (drw18) for their individualized help in this process, ill get pics up soon, and keep everyone posted on how the new changer/sirius/subs/hidden radar detector process goes... this audio stuff gets damned expensive
sounds nice, and yes it does get expensive. i was wondering why no cap. i have a cap that i just tore apart and fixed b/c it broke in my last car when someone stole my subs. i was going to hook it up to the system and would like to know why that is a bad idea.
heres the deal, its not so much a bad idea, its just an expensive one. if you have a half way decent amp, and were to take it apart, you would see a ton of tiny litttle capacitors inside your amp. my depth charge for example has about 10 (+ or - a couple). these internal capacitors do the exact same thing as an external one would, without the added cost and complexity of an external cap. my point, is that rather than spend the money on a cap and the install of it, spend the extra money on higher quality components for your system, if you already have a cap its not gonna hurt anything. was that clear?
A large cap is going to store a lot more energy than those little tiny ones you see imprinted in the circuit board.
Sounds good with the install, I just got 90% of my stuff installed in the 97 this past weekend, should have it all done tomorrow...I also have comps front and rear and think they sound awesome, although my front comps are in kick pannels, I think that adds a lot of sound to them...Good job dude!
