JBA headers question | Ford Explorer Forums
Dre
Largo, FL
2015 FPIU
Anyone have a part number on JBA shorty headers?? Also I need to know if these headers will work with factory Y-pipe?
talking about a 4.0L V6 engine in a 94 Sport.
thanks,
I'm pretty sure you need to use the JBA Ypipe and collector pipe.
GO TO JBA'S WEBSITE AND LOOK UP THE PART NUMBER. whoops caps is on. And like alec said no it wont work with the stock y pipe because the headers are just longer than the stock manifolds. I know also because i called them and they told me this. If you get them on make sure get either the ceramic or have a temp coating put on them because i have them (no ceramic coated) and the heat that they produced burnt some of the insalation on the ac .
I think
JBA16331-1. Check the website to be certain.
Greg
OK... thanks. I'mm looking at a set of these headers and don't even know if the guy has Y pipe or not. Also I might just consider buying regular manifolds. My Y pipe is still OK.... that and replace rear mufler.
thanks again,
