- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
How many miles on the truck Hartman?
Also dont keep throwing $$$ at it.
Jerking like that is usually:
fuel pump or relay
Also could be the 02's, especially with a CEL, it will run rich or lean and either load up or starve you for gas.
Could also be a clogged cat, could be a bad plug or wire, but your best bet is to pull the codes...get in the zone...
90% of the time the CEL will point you in the right direction.....
fuel pump or relay
