chris288
- January 22, 2014
- TN
- 2002 Ford Explorer
Hey everyone, need some help here on my 2002 Ford Explorer limited 4.0 V6. Bought a used engine from junkyard ( Did hear it run and checked oil before) so I believe the engine is good. Its got 74k miles on it.
Had my friend put it in because that is a little to much for me. Just started it up and smelled some coolant after it ran. Forgot to change the old oil out, so figured that it was old. Well when I dropped the drain plug it poured pure antifreeze/water for like 3-5 seconds, then milky white oil. It overflowed the oil drain pan.
Since its the first time its ran since replacing the engine, I drained the oil and left the old filter thinking I will have to drain it again. So started it back up and it sounds and runs fine, except I can smell and see a little smoke starting at the side of the engine on top I think under the throttle body and air intake. I only let it idle for a couple mins, because I looked down and it shows zero oil pressure, so I shut it off.
I pulled the dipstick again, and its got some milky while on it.
My question is what could have went wrong? New water pump and it sounds good at start up. Maybe he didn't hook up the oil pressure sensor so that is why no oil pressure, but it scares me to let it idle.
I am concerned about the milky white dipstick. I haven't drained it again to see if lots of antifreeze again comes out, but this worries me. The engine was complete and it was just a replacement engine that had to be hooked up. Could something be hooked up wrong? I dunno what to do or check next?
Could it be a bad engine?
