Just to say thanks!!! | Ford Explorer Forums
jcm2006
Jackson, MS
Ford Explorer 1992 XLT
Couple days ago just found my Explorer 92 just died on my driveway, after many attempts I just realize the fuel pump wasn t priming like usually, in fact couldn t hear the typical noise. Back in time since last April it was making funny noises at time to crank it up, it was like the flywheel got missing teeth. I ran to the mechanic and he said "it is the fuel pump, I wont replace that, just make a few try with the key on ignition position and you ll be ok". Then when I found it dead my first thought was "prophecy was right, fuel pump is gone". Then I did a research in this forum and found a lot of useful info, tips and the best attitude. Can t remember names or threads, I think most of them about fuel pump and relay failures. Short story, thanks to YOU I got my problem fixed just replacing the fuel pump relay and the ECM (?) relay. Don t remember wich one but one of em was rusty and holding water at inside, I don t know how to post a picture but it will be nice to show you how bad it was. THANK YOU ALLL!!!! If there s someone here that need additional info about kind of relay replaced or something else that i can help just let me know!!!;)
Welcome to the forum, glad you got it fixed!
...Welcome here..
.."Bumping" (posting in the thread to bring it to the top) the threads that helped you out will say thanks to the authors of the thread and will bring them to the top so they are easier for others searching for the same stuff..;)
..Glad you got it fixed...:biggthump
