Key/door alarm. | Ford Explorer Forums
Key/door alarm.
jefe620
liberal ks
'93 eddie bouer
:exp: Hello, i have a 93 explorer and i have a problem with the headligths alarm for some reason when i turn the lights on the alarm inside of the truck start beeping and that also happend when i remove the key from the switch. A friend told me to change the ignition switch cylinder but i just replaced it and didn't work and the alarm its driving me nuts. Does anyone know how to fix that or disconnect the alarm???
Pleaseeee.....
Mine started doing this on my Bronco II - I was driving down the road and the door chime just started dinging - ding, ding, ding, ding, ding - thought I was going to lose my mind! IT is located just beneath the cigarette ash-tray (mine was a white box) with a 5-6 pin connector going into it on the driverside... Removed the connector - problem solved.
welcome
Thanks man this thing was driving me crazy, but finally i found it, disconnect, problem solved, just like u said jaja thanks again:salute::salute::salute::D:D:D
the only diference was the color mine is black jeje
