keyless entry system | Ford Explorer Forums
maguinness
Tampa, FL
1995 Explorer Xlt
does anybody know if there is a fuse or relay somewhere for the keyless and keypad system on 95 explorer its not working. thanks
The computer box that controls the keyless entry system is located in the cargo area on the left side behind the plastic wall panel. You might check that to see if a wire is loose or something. But first check for blown fuses. I don't know much on this topic but I hope I helped and good luck!
thanks for the info i will check them if not i will pull it out of my spare parts explorer.
