keyless entry | Ford Explorer Forums
keyless entry
maxerious
2000 XLT 4X4
hello i have a question i have a 00 xlt and i am wondering if i can get a after market keyless entry/remote start for it it has the pats key system plus it has the button panel on the outside of the door that works fine but i wasnt givin a remote when i bought it used is this because it isnt really considered keyless entry or can i get a remote for it and program it thanks
Is the keypad on the door the factory pad? I have seen the aftermarket door pads act as a second remote. With the A.M pad you cannot program another remote. If it's the factory keypad you should be able to get another fob for it. Make sure the numbers on the back of the fob match yours. You can program it yourself.
ya its the factory pad at least it looks like it plus the number i pulled off the module in the back works for it its were ig ot the code were should i look for a remote ebay and how to i make sure it will work with mine .... thx
i was just reading on a few diff pages and it stated that just because i have the keyless entry keypad on the door it might not be compatialbe with fob remotes i know it was stated above that it would work just looking to get some more input anyone else know or has done this before? thanks
remote
Key fob remotes are cheap on ebay - I've ordered them there for several cars, they come with programming instructions and work great -
Ron
to program--- turn ignition to the on position then back to off 7-8 times. The doors should lock and unlock by themselves. Press the lock button on both fobs at the same time. As long as both fobs are the same you should be programed.
