Kirby N.
- February 6, 2001
- Colorado Springs, CO
- 1991 Ranger
Yeah, like 93,500 pennies!!
The reason I went with the JD arms are numerous, but the main one was I was not very confident in my fabrication skills when I started the SAS. As I progressed and realized that I was decent at it, I figured I could have made my own arms. Then, I thought about the RA's being so critical to a good build and that JD's are so well thought out and strong. I also was thinking there was no way I could fabricate arms with the forged steel mounts like these. They weigh several pounds each and are just plain beefy. Also having the arms bolted to the axle mounts with separate bushings keeps them from binding. When they showed up, I was very impressed with the quality, fit and finish.
You should be confident now. Your truck turned out amazing!
As far as street drivability, I don't have any reference. The old TTB setup seemed to lean and sway much more than the SAS. I think the longer arms act as sway bars. When I had the light valving in the shocks, there was a lot of body roll during slow speed turns. Now, with the medium valving, its mostly gone. At any speed over 15 MPH, there is hardly any body roll on tight curves. I wish someone made wedgie bushings that were set about 4.5*. The 6* was too much and the 3.5* is too little. Highway steering is a little sensitive with the 3.5's but the drive line angle is much better.
Longer Radius Arms do act as sway bars, just less than the shorter ones. The longer the arm, the less they bind with each other when they are traveling the opposite way.
You could always fine tune your caster with ride height...
