I think I settled on trac bar mount locations or atleast close. So I ordered drag link an trac bar. The tb is 24.25. Dl is 23.25. I will likely tilt the axle mount less, but I will have to see how the bar clears the diff/ crossmember. The upper mount had to be tilted too to clear the tierod, so I may need to run a ballistic joint instead of a poly joint since the mount isn't ventricle there may be a bunch of lateral movement required.
I also installed the new power steering pump and plumbed it. The pulley was a pain in the butt! All new power steering now.
after getting the pump off it looked like it had been leaking so I think it was a good investment. It was quiet though, I hope the new one doesn't ford whine.
