Byrd91
You say it does not ping for the first few minutes of a trip. Hmmmmmm, maybe something in your engine is heating up too much. What is the situation regarding your radiator, water pump, and thermostat arrangement - perhaps your engine is getting hot? And if you think the KKM is allowing too much air to enter the manifold, you could block off or restrict the airflow some (wrap a cloth, rag, aluminum foil, etc. around part of the KKM filter to restrict air flow) and if the ping goes away you know it is related to the air flow. And there is the oxygen sensor in your exhaust system. Maybe this O2 sensor (upstream of the "cat") arrangement got screwed up when the Flowmaster catback exhaust system was installed - the air/fuel flow rate ratio is set using this O2 sensor signal and if the computer is somehow giving a too high air/fuel flow rate ratio (lean setting) it is (I think) more prone to ping. I have a KKM induction arrangement on my 91 XLT Explorer 4x4 and no ping (but it does not get very hot in Western Washington). Keep us posted on what happens. Mike in Seattle
