L.e.d tail light problem...help!! | Ford Explorer Forums
mercer21
NEWFOUNDLAND CANADA
2004 EXPLORER LIMITED
hi i picked up those LED tail light bulbs the ones that replace the exsiting stock bulbs and i installed them and they work great only now when i turn on my turn signals they flash really fast almost like when a bulb goes but the only differance is all my lights work fine..what could be causeing this problem.
or pick up some 50W 7 ohm resisters and wire them to your flash wire...this option will run you all of about 9 bucks. and 10 minutes of your time.
thought those LED tail lights were plug n play? who did you order from?
i think he just did bulbs, those LED housings ARE plug and play. he just needs a resister to solve his problem.
