sleeprae
- December 17, 2002
- Manhattan, KS
- 1993 XLT
Okay, here is my setup: 1993 XLT w/factory alternator.
I purchased and installed the following:
1. Pyramid (POS, I know, was free) 800-watt amplifier powering 4 Pioneer TS-A6857 speakers
2. Kenwood KAC-929 1000-watt amplifier (460x1 bridged rated RMS output) powering (1) Kicker CompVR 12" subwoofer (Rated for 400-watts RMS)
3. JVC KD-SX980 MP3 HU
4. Harness kit/amp bypass for premium audio.
I replaced all the door speakers and installed the amp bypass. I have RCA Low-level inputs (coming from HU) going to my two amps, with the front channels split to divide the signal between the amps. The door speakers work and sound great - but the subwoofer seems to lack punch. The cone moves, and it makes sound, but it's not near as loud or powerful as the CompVR should.
Wiring: #4 wire going from the positive block next to the battery to a distribution block (Rated for 600-Amps) near the amps with 3 #8 wires coming out, 2 hooked to the Kenwood and 1 to the Pyramid. Fused at battery with a single 100-A fuse. One #8 ground wire per amp connected to the chassis plate below the factory cupholder (that is where the two amps are mounted). This cable is about 12" long.
Problem:
As I said, the subwoofer doesn't hit near as hard as it should. I suspect power wiring, but was hoping someone here could shed some insight as to where to look. I have a suspicion that I'm not getting enough power from the battery/alternator to the positive block thing mounted to the chassis next to the battery. When the bass does hit, the lights dim significantly.
Also, does anyone think that I should buy a new alternator? My estimate is that the two amps pull a combined 80 amps or so, maximum. I've read that Ford uses a 95-amp alternator stock. Can anyone confirm/deny? Thanks for all your help!
Problem:
