1996BLKBauer
- June 24, 2011
- McHenry, IL
- 1996 Eddie Bauer AWD V8
So since I can remember my Explorer has had a lag between me pushing the pedal, and the engine responding to it. For normal driving, it's not so noticeable, but when going up a hill, or passing somebody, it is very noticeable.
For example when I go to my college everyday I go up this large hill, and I hate being that person who is going up the hill at 20MPH, when the speed limit is 45, so I push the pedal, and 1, 2, 3, 4, seconds later the engine responds to it. It responds well, so I believe that the mechanical portion of the engine is in good shape, But is just responds slowly. I am uncertain if I am the only one with this problem, or if this is common.
I was just tossing idea around, and I thought that possibly the Throttle Position Sensor is maybe worn out? But on the other hand I think that if I am opening it up farther then normal, then there should be no problem because it is used less. I am fairly certain that all the TPS is a variable resistor. So does anybody else have any ideas? I am in a class right now regarding sensors, computers, ect. So if I need to test anything, now is the time.
