Lamp out module and now fuel problems. | Ford Explorer Forums
Tilt Man
San Francisco Ca.
95 Explorer XLT
Bought a 95 xlt with no issues in 2020. Since buying it I've always been able to handle any of issues that do appear. Have put in a used tranny with transfer case , new brakes , tires , alternator , battery the usual for a rig this old. I've Explored the states from here ( San Francisco ) to Miami. I literally cherish my XLT. This is also my daily driver and work horse . Now for some reason I'm getting no fuel even after changing out the obvious pump , filter and relay. Plus there is No Lamp outage module in this model.....yet my driver side headlight did all the things described by everyone with the L.OM. before going out for good. Any ideas would be appreciated. Thanks TILTMAN
Have you checked the fuel pump safety inertia switch, passenger foot area
Should be a relay box under battery which may affect headlights.
Trace where power stops, using the 2nd gen wiring diagrams linked in my sig below, though the obvious first step is check the fuse.
