Leaf Spring woes | Ford Explorer Forums
Leaf Spring woes
Robert Johnson IV
Location
Coppell, TX
2000 Explorer Sport 4wd
So I'm new to the 2000 Explorer sport, so when I went to replace my rusted thru shackles I just went to my local Autozone to get a set. Put my truck up on a life I have access to, and went to work.
Ended up cutting them out - no biggie - but then the real fun started. WHAT THE HELL IS THIS EXTRA BUSHING IN THE FRAME?????? Not one auto parts store carries these things in my area. So my truck was STUCK on the lift.
After 48hrs and then me finding the part number finally to buy these $50 ea bushings - I decided screw that nonsense. And spent some time in front of my CNC machine.
end result - Aluminum Bushings... not buying the $50 replacements - EVER.
Ride feels awesome now!
Props for being able to make your own! Were the old ones not reusable?
Welcome to the forum!
Thanks, yeah not at all. They had to be drilled out. My explorer is from Ohio, and covered in rust. So it's my $800 project turned daily driver.
Can you link the source for the $50 bushings? I agree they shouldn't cost that but for reference's sake and the seller might be a source for other hard to find parts...
^ Thanks. The original is rubber but you're going with aluminum? How is that working out?
Yea, the original was rubber. The aluminum replacements are actually perfect.
I have not seen any issues thus far. I've been pushing this truck much harder to see if I would have an issue.
The next time I have the truck on the lift I'm going to pull them out and inspect them for wear.
So I'll let you know.
