Leaking Anti-Freeze | Ford Explorer Forums
Leaking Anti-Freeze
JMT1SOMR
Lakeland, TN * Oxford, MS
'95 XLT
My car is leaking antifreeze from the "valve" i guess it is where the antifreeze line makes a junction and goes through the fire wall to the heater core... i dont exactly no whats leaking... i jsut no it is... also... my car seems to be revving a lil higher than normal and im not getting the same power... could this be due to a vacuum line being off somewhere... any suggestions are greatly appreciated... oh yeah, i have a 4.0L OHV... thanks yall
-Justin
Heater Valve
The valve you are refering to is the heater valve. I had one go bad not to long ago. The rubber that seals the plastic casing and the plunger seemed to rip. I got mine at NAPA for $13. It took about five minutes to replace with pliers. I don't know about the other problem though.
thanks... ill get that fixed tommorow.... thanks again... now on to the other problem
