leaking cv shaft at axle...pic included | Ford Explorer Forums
97splorer
Overland Park, Kansas
'97 XLT 5.0 AWD
I noticed that on the passenger side front axle is leaking where it meets the CV joint. It also appears to have some movement when shook. I have a feeling I have finally discovered the source of the binding/shuddering noise I here while driving. Can anyone tell me what I need to do to fix this issue?
Also, the leak is not major but I can see residue from what looks like grease has escapes the axle.
Here's a pic of the problem, area...
vbgarage.php
THANKS_ Brian
There's also an outer bearing just inside of the axle seal. If you can feel play, that might need to be replaced, too.
