Leaky Transmission | Ford Explorer Forums
Leaky Transmission
OGBlackcloud
California
2008 Ford Explorer
Hey all, I installed larger tires yesterday, drove around for a while testing them out, drove home, parked in my driveway, and noticed leaking transmission fluid and coolant from my 2008 Ford Explorer XLT, V6, 4.0L SOHC 4x4.
No chance these two things are related, are they? Didn't have this problem the day before.
For the transmission fluid, it seems the seal on the transmission may be partially separated, but the screws seem fully tightened on. I'm less concerned about the coolant as that could just be exhaust/condensation.
Thanks for the help.
do you have the v8 or the v6?
Should have clarified. I have a 2008 Ford Explorer XLT, V6 4.0L SOHC 4x4.
the transmission cooler is physically embedded inside of the radiator on these rigs, i would check for damage there.
Thanks for the information. I'll take pictures tomorrow to post for reference.
As promised, areas highlighted in the red box I have found wet with transmission fluid.
I took the liberty of tightening all screws shown today (they were already quite tight) so I'm still stumped as to a possible leak cause.
Bigger versions of photos:
https://postimg.org/image/j18a5puh1
https://postimg.org/image/z0qxp9qit
https://postimg.org/image/mne3id0ud/
Sorry for the late response -- Was away on business. In the highlighted red boxes is where the leaking is coming from at least that I can witness. Is that something that might have a broken seal, or any hoses that are above it that could have a crack?
