Led flasher - does flasher relay exist for 4th gen? | Ford Explorer Forums
seth21
Georgia
I just swapped puddle lights to LEDs abs want to do flashers but avoid hyper flashing.
The post below has conflicted info, one guy says get the flasher relay for LEDs and the last post says the relay is integrated and can't be swapped. Looks like most people go with the 'canbus' version which has the resistor built in to avoid this hassle but i dislike the idea of having a resistor since they add power draw and increase heat.
https://www.explorerforum.com/forums/showthread.php?t=275045&highlight=Flasher+relay
Can someone confirm if this relay can be swapped on our Xs?
I have the resistors in my X. Everything converted to LED on the outside, brake lights, marker lights, fog lights and then HID headlights. No problems here, but I would also like to know if the relay is swappable. I like that alot better than the resistors.
From what I have read there is no flasher relay. It is part of the sjb and you have to use resistors to prevent hyperflashing.
