Benster24
- October 8, 2022
- Missouri City
- 2015 Explorer Limited 2wd
Hello,
I have a 2015 Ford Explorer 2WD with 76k miles. The car for the last 2k miles when driving between 15-35 mph driver's front wheel has a randon grinding noise. The grinding or gear like activating noise doesn't happen all the time even when I drive down the same curvey roads or turns. I have already changed the wheel speed sensors in which the original sensors were clean with no debris.
There are no check engine or other diagnostic lights, but running bluedriver diagnostic stated code U0415. The ASR light sometimes comes on when the car front drivers wheel had a grinding noise or the wheel is re-positioning itself for a second but it can be a repetitive noise back to back. Almost feels like the tire is disengaged itself. Almost like the front wheel stops turning and the the passage wheel keeps going with a slight jerk on the grinding wheel/drivers side wheel.
Please help since I did have the ford dealership try to locate the problem for 2 weeks with no definite answer ranging from transmission to ABS control module issues.
Any help would be greatful since it's been 4 months of this issue.
Thank you,
Ruben
Thank you,
Ruben
