bchess
- April 3, 2005
- St Charles, Illinois
- 1997 xlt
History: 145 k miles, serviced at 30k, cooler added at 90 k.
once upon a time, Over a long period of time the Drive trane developed a clunking sound when coasting down a large hill, no other slips. then all of a sudden going down hill one fine day, I lose all drive, The trannie felt like it was in neutral, I coasted down the hill and up the otherside came to a stop at a stop light, the vehicle would not move, but the engine would rev up. I tried to put the gear shifter in to 1,2,d n,and r and no movement. tried to put it in park and it started to grind. I shut the engine off and put it in park, started up engine and put vehicle in drive and off I went. It seemed to slip and the o/d light flashes, I drove it home and parked it.
Day 2....Start, drive, shifts ok from 1 to 2 to 3 about 32 miles perhour it won't shift higher and the od light starts to flash. (od light stopes every time you stop the engine and then reappears flashing at about 32 mies per hr.
Day 3,4,5.......start reading everything every where, found explorer forum.
Day 6.....drop trannie pan for my 1st time
fluid was as expected, dark, checked the bottom of pan, found some little metal barrels just like the ones in the Gasket, no other parts or parts of parts were present, I wiped her down real good and replaced the Filter and gasket, tighting down thumb tight with just the barrel of the socket, then just a small sinch on each nut, added (3 1/2) quarts Mercon V at $3.25 a quart. connected the battery cables, and off the test drive........failed again at 32 mph and the od light started to flash.
Day 7,8,and 9 ..........read some more called shops talked to mechanics at Ford, The Parts guys were great copied a few pages out of the SERVICE manual which is completely different then a Chiltons REPAIR manual at your local Library.
Day 10 figured it was time to purchase an OBD II and get the codes. I Purchased an Actron at Pep boys for $99.00 with $20.00 rebate. I needed to know which codes were pulled to determine which solenoid or sensor is acting up. plugged her in the dtc turned on the ignition, darn it if it PASSED everything! started her up and drove till od light came on still no codes.
A lot has happen in the past 10 days some funny and some sad.
yes I did loosen the overdrive nut on the outside drivers side of trannie, yes it did stop turning after about 2 1/2 turnes and yes I did back it off and retighten the 3/4 inch nut.
I did buy the top and bottom gaskets to the Valve body. but was not ready to disassemble unless needed.
I do have a good schematic of the VB and have identified the solenoids but have not purchased.
4 shifting control (7g484) $ 58.12 from Ford
Pressure control (7g383) $ 134.07
Torque converter control (7g136) $ 84.08
A couple of questions:
Craftsman Torque wrench 3/8 drive is all I could afford $ 75.00 (in/lbs)
didn't see a 1/4 in drive.
Rebuilt VB from the Internet about $240 ( it say's it comes with all the solenoids) that would be a bargain I think considering just the parts from Ford would be more, Ford wants about $500 for the Valve body but it wasn't clear to me if the solenoids were included. Has anybody actually bought a rebuilt Valve Body from the Internet?
or test and rebuild My self
Yes time is critical we only have one working car at this time ( I do rent from Enterprise over the weekend for $9.99 a day).
To any one who responds thanks in advance.
Well let the questions start, I'm ready to follow your directions and LETS GETTER DONE !!
