Leveling Kit / Lift Kit | Ford Explorer Forums
Ford Explorer2006 4.6L V8
Hello guys,
I want to lift my explorer with strut spacers which i will go for that but just wanted your opinion about the size of strut spacers?
Supreme Suspension available Front 3" Rear 3" / Front 2.5" Rear 2" / Front 2.5" Rear 1.5"
Traxda Front 2.5" Rear 1.25"
This is what i found available for the moment and the question is which one you suggest?
Should it be the same size Front and Rear in order to be leveled? Which one will give less stress to ball joint?
Cheers,
Gerald
The smaller the lift, the less stress there will be on your ball joints and control arms.
I also recommend that if you want more height for bigger tires, ensure you check out the BTF upper control arms.
I wouldn't go higher than that unless you get BTF control arms, but those are $750 i believe.
