lift help please | Ford Explorer Forums
lift help please
wbuckworth
eastcoast, delaware
05 4.6 k&n, Thrush
i'm new to this forum so sorry for any mistakes..now , I want to put a 2 to 4 inch lift on my 05 4.6 explorer all the local shops say no one makes one. find that hard to believe.doing a lot of beach driving lookin for ground clearence and bigger tires any ideas????????
i have a ranger so i dont know a lot about lifting X's but i know a lot of guys here talk about SOA spring over axle to lift the rear. not sure what they do to the front though.
X's have IRS so no axle to "sripng over". Look around this site. Many people have done body lifts and suspension lifts. I think they are using spacers on top o fall the struts to get the lift.
lol like i said i have a ranger so not much knowledge on the X. i know the older ones have axle,not to hijack the thread but, when did they start the IRS?
gotcha
Here's the scoop. You need to use the search feature and LOOK AT THE STICKIES at the top of this forum. Read, Read, Read. I'll throw up what I can type out in a couple minutes
Explorers have a fully independant front and rear suspension. This makes lifting these truck a bit more complex than lifting your average Heep, ranger, and full-size truck.
You have 2 options:
1) 3" Body Lift. you will keep factory suspension geometery and factory ride. The only change will be due to your change in tires. (All-terrain ride a bit more truck-like, stiffer)
CAUTION: This body lift is designed for a Ranger, you will need a little bit of modification (filing, and buying new bolts) to make it work.
2) Spacer Lift: this lift simple moves your existing struts downwards, you will also ride pretty close to stock. You WILL need a alignment after this lift.
Options are BTF Fabrication and TRUXX. The BTF kit is a direct bolt on.
A 2.25 kit will net you 3.5" of lift due to your suspension geometry.
Here's the install of that lift kit: http://www.explorerforum.com/forums/showthread.php?t=279667
TIRES: you can mount 265/75's (32's) on your stock rims. General consensus is that this is the largest you can push factory rims and backspacing. If you have spacers or aftermarket rims, you can mount 285/75's (33's)
thanks for the info i'm gonna look into the BTF lift... You woulnd'nt happen to have contact info??? thanks again......
he is a site vendor search his name,,,
search well young jedi the force is very strong here,,
I gauranteeeee it's in the thread I linked above... otherwise his website is linked in my signature.
