Lift kit question | Ford Explorer Forums
Lift kit question
bgh1441
Shelby Township, Michigan
'94 Eddie Bauer
I can possibly pick up a 4 inch lift for the front. Its coming off a bronco 2. will this fit my explorer? I am assuming it does but want to make sure.
What year of Bronco II did that lift come off of? I am not sure if the beams on the Dana 28 are the same size as the 35. If they are, it should work just fine. What kind of lift is it?
it will be coming from a 1990.
That lift should work. The sway bar brackets may be different but I would think everything else would line up just fine. You don't need sway bars anyway... whats the plan for the back end?
My lift is off of an '87 (I think) BII. It took some effort, but I think it was because of my truck not the lift.
theres a spring shop by me that for 260 a pair will make leafs to any height i need.
Springs can get "re-arched" with the proper equipment. Not many shops are capable of doing this, though, and it's my understanding that with the cost associated, it usually ends up being close enough that you'd just as well have replaced the springs.
Not to mention that re-arching a spring generally tends to weaken it, or it will still be soft as it is still the old spring, just with a little more bend. If you can get them done properly it may work out well, but all the people around me I've talked to who re-arched their springs (we have a shop who can do them around here) recommended to not bother with it.
It was a great option back before the aftermarket really kicked up with lift kits, but now it's kind of an outdated procedure.
these will be brand new leafs.
