ryboj
- December 20, 2010
- Northern NV
- '92 Dora XLT 4x4 5Spd
Guys, we sold our '93 Dora last year. It worked amazingly well for what it was, but it was getting tired (didn't want to rebuild) and was also cosmetically challenged in many ways that we inherited, so we picked up a Dodge Ramcharger and built that up. We're near done with that and decided to pick up another X since they just seem to perform so well, even with inadequate parts to some degree...I'd say quite underrated as a 4x4 machine!
So, we just picked up a super clean, lower mileage '92 with a factory 5spd, never been in 4 wheel drive, CA only, and I believe it, clean interior, and had only a bad heater core, whinney PS pump, missing subwoofer and a small rear main leak, along with the infamous clear coat coming off. Either way, we were tired of having the weaker A4LD, so this time we did it right and got the M50D! Yay!
Ok, so here's the thing. Our last Dora already had the lift on, but we did add Bilstein 51xx's to it, which are btw an amazing shock. The last one had a 4" Tough Country Lift, fact radius arms (not extended), legacy based Rough Country 3" lift rear springs and Warrior shackles. Believe it or not, this truck did amazing. It was also running on 32x11.50s, stock 373s and a fairly worn fact posi. For what it was, performed great!
However, now that we have a base platform from which to work and we'd like to do it right the first time, here are some options I've put together. Just trying to see what makes the most sense here. We're not on a shoe string budget, but we are on a budget and we're looking for something functional, reliable and cost effective, and doesn't wander like a kid on a bicycle. We'd prefer not to have to buy things 2x or swap things out later. No reason for us to do it wrong the first time.
Will be used for 50% mountain trails, mild to intermediate, 40% open desert and about 10% dunes. Would run a 32x1150 tire most likely, and maybe a 33x1250 if went larger than 5".
1: 2.5” JD Full System 1699 + shipping, dual front shocks, deaver springs included, add cheap
pitman arm too potentially
2: 5.5” JD Full System 1900 + shipping, dual front shocks, deaver springs included (need
driveshafts lengthened front and rear, maybe 175-200 each end)
3: 4” Tuff Country with Tuff Country Arms, 4” Rough Country Leafs, Bilsteins,
roughly $1530
4: 4” Tuff Country with JD Arms, 4” Rough Country Leafs, Bilsteins, roughly
$1980
5: 5.5” Superlift with SL Arms, Rough Country Leafs, Warrior Shackles,
Bilsteins, roughly $1380 (need driveshafts lengthened front and rear, maybe
175-200 each end and longer brake lines)
Note, I'm aware, Superlift front drop pivot brackets should be reinforced some (weld them up stronger), and their Extended arms are def not as good as JD’s. I would imagine SuperLift and Tuff Country arms are near as strong, both with pro and cons in terms of design, but obviously JD’s are better, but also a lot more money. SkyJacker arms great too, but likely just do JD's if already looking at their kits too.
What do you guys think?
What would be the sweetest combo here, to meet those goals, and not totally break the bank?
Anything I'm not seeing or taking into consideration here?
We'd likely stay at 3.73's for a while, since we just bough full gears and a TruTrac for the Ramcharger, so gears will need to wait for some time.
Thanks all!!
roughly $1530
$1980
Thanks all!!
