XplorerWannabe
- April 22, 2005
- Charleston, South Carolina
- '03 Sport
Since I have a 2wd '03 sport you guys suggested that i get some spindles for 3" with a TT for 2" for the front and then a soa for the 5" in rear.
How will all this stuff wear? Because I'd like to go awhile without having to replace anything. Like will anything ever go back with the soa? I always here about the wear to the torsion bars and such so I was thinking that I should either just go 1.5" and since it looks like the rear is a bit lower anyway that might make it even or just go without the TT but then I'd have to do the shackles and aal for the 3" in the rear instead of the soa for the 5". Is the soa 5" or nothing or just adjusted to whatever you need?
Basically I want to go with the option that I can run for the longest period of time without having to worry about much wear or problems. So would you guys suggest the 3" option (without TT but with shackles and aal) or should I stick with the 4.5"-5" option?
Much appreciation goes to all you guys that know your stuff about explorers.
