Lift options | Ford Explorer Forums
Lift options
Stonyhill429
Wake Forest, North Carolina
'99 xlt
ok, ive got a 1999 xlt sohc exploder. if anyone has some lift options outside of trailmasters 1500 dollar option or Blitzkrieg's 4000 dollar option it would be nice. i want to fit 31''s on it.
Wow just a little vague there skippy. I'm sure if you did a search for what you're looking for you'll find it. BTW you should be able to fit 31s stock.
yeah, sorry about the vaugeness. I did a TT about 5 months ago, without following instructions, and lost a front drive axle in about 30 minutes of regular driving. replaced that. Do you know if the stock shackles can be adjusted any? ive got the TT done properly now, so ive got about 1.5-2" in the front. Now, if 31's will fit stock, is that an aggressive 31 or a street 31?
You're options for the rear to match the TT is AAL, or shackles (aftermarket). Autozone sells a really chap set ($12. They're fine for on road stuff, but I bent mine off reading to hard. And you can get a set of warrior shackles, more expensive ($60), but they're pretty heavy duty part #153 (gray), #353 (gold).
Ive looked into Warrior Shackles, heard alot of good things about them. now,ive asked around before, but would a ranger BL work on an explorer. the only reason i ask is because i havnt been able to find a BL specifically for a 99 xlt
Thanks man.
