Lift Question | Ford Explorer Forums
Lift Question
That'll work and I'm pretty sure there have been a few people on here that have ordered from them. They've got pretty nice prices too.
Thanks
Thanks for the quick response.
Sorry it took so long to thank you.
Should I buy new U-bolts when I do the install?
Also they sell a kit on ebay same basic parts but including the cams and the stud extenders,(may or may not need the 2nd part) for $189.00 what do you think?
You shouldn't need a lift to fit 31's. At least that's what most guys on here say.
I bought a 2" lift system like that for my X and didn't need anything but camber/caster adjustment shims to correct the alignment issues after the lift but thats only because im running some aftermarket springs that are alittle stiffer than stock. you may not need anything but the kit, but every truck is different. I didn't need the stud extenders, actually i had plenty of stud on my shocks left over, enough to be able to shim the bottom to return them to the original height. You will notice the difference in the height of your truck, the kit does make it look better than stock. But beware, once you start there you will want to go higher, i did now im gonna be 9 " lift and 35" tires, and broke! But the truck will look good! LOL
9" is huge
Man that'll look great when you're done. I'm sure I will want to go bigger later This is only the beginning... :hammer:
Sweeet!
