Everdream
- March 13, 2010
- Lakewood WA
- 2002 Explorer Limited
Hello,
I have a friend who just purchased a 2000 Ford Explorer XLS 4.0L Automatic.
We are having a few problems: One: The Headlight SWITCH, Heater control panel, and dimmer switch do not light up INSIDE the truck. the CLUSTER, DOORS, and rear defrost/4x4 DO light up. the brown wire comming off the dimmer had a very bad job of some aftermarket fog lights hooked to it. so I had to remove that wire and reconnect it to stock.
two: there is after market fog lamps, does anyone know how these typically get installed? should I just run the + wire I removed from the dimmer switch to another ignition powered source?
I checked the brown wire when I was playing with the headlamps, and got no 12V reading with the lights in the on or off position, could this be the problem?
(Also: all outside lights work (except the fog lamps))
M
M
