1997XLTRollover
- February 28, 2007
- 1996 AWD 5.0
Hey guys, does anyone run limit straps with a TT? I've noticed that when taking off at WOT I get a bad vibration which seems to get better in higher gears and if I lower the front end down to stock height. I'm thinking the front end is lifting too high and causing CV bind. I get an even worse vibration too if say I go over train tracks and the suspension lifts.
I only did a 1.5" TT in the front to be sure I was safe. I can get a solid 2" but backed it off to avoid excessive wear. I measured where my CV bind point was and it's 8" from my tire to fender. I have my front suspension sitting at 6.5" which is 1.5" over stock.
Has anyone else ever had this problem?
