Final problem
I'm posting this for any that may be having a similar problem. The original problem was chugging/no power after driving a bit. Seemed heat related. My service engine light works, but gave no codes other than MAF, which I replaced. So I ran a fuel pressure test and it checked out fine. I replaced the coil, wires, plugs, CPS, TPS, cleaned the IAC, finally... even though it checked out okay, I dropped the catalytic converter. No change.
Now here is what 3 weeks and lots of money and cussing taught me.
Never... and I mean never.... do a pressure test without driving. You can brake torque all you want, it's not accurate. So I do one last fuel pressure test, I snake the gauge up through the hood to my windshield, make sure the line doesn't get pinched to hard when you close the hood(only to safety latch). Now, drive until it acts up... And there it is.. pressure drops from 34 to 10. Regulator works, new fuel filter doesn't help, no pinched lines... you guessed it... a fuel pump that looses pressure after it heats up under load.
SO... I spent around 600 to fix this myself and learn this lesson. The good news is I have a lot of new parts that I don't have to worry so much about in the future, a tune up, and a fuel pump, all for about the price of having a garage fix the pump anyway. Any education worth having is worth paying for anyway!! LOL
My thanks to all who helped on this, and also to Burns for the photos of fuel pump location through floor.
http://www.explorerforum.com/forums/showthread.php?t=182160 I sorta used it with a twist... I'll comment there.
