Nitrous SSC
- October 17, 2002
- Layton, UT
- 98 Eddie 3-oh-2
I only owe 3k left on this thing and I'm trying to decide either to sell it or keep it and drive it till the wheels fall off. Its got 115k on it.
#1. The front of my explorer groans when driving. Granted I know I have Big O XT's that are a pretty agressive tire its damn loud compared to my friends ranger with the same tires...Both Hub/Bearing's have been replaced. DAMN that was expensive. Fixed nothing. I'm thinking about changing the CV's Do these moan/whine?
#2. The rear end whines like a mother. Its so loud it sounds like a monkey installed the gears and set them up wrong. It wasn't like this when I purchased the truck. I have changed the fluid when I did all new bearings and seals. I'm thinking its a get setup issue. I'm just wondering if anyone elses X started to do this.
#3. The drivers side valve cover has started leaking. It stinks, and the "low oil" warning comes on about once every month and my X is now marking its territory. Can I change that drivers side cover gasket without pulling the upper? I'm used to the smaller one on my stang.
#4. The Center concole/armrest has ripped and gotten nasty looking. Where is the best place to get an OEM ford replacement one, I'm looking for a tan one.
#5. The offset of the aftermarket wheels has them sitting in a little far and the front tires rub on the sway bar and the rears rub pretty good on the rear splash shields. You look at my truck and you can definatly tell they're in to much. Where is a good place for 1" spacers that bolt on with their own studs? I don't want the cheap spacers.
#6. The heater....I can't stand this issue and no one has been able to tell me whats wrong short of going to the dealer (and I've talked with 3 friends that WORK at dealers) It vary's at the hot/cold break over point but it will either blow full hot air or cold air. Sometimes its 83* or 85* it will change. The blend door is brand new installed by Ford. I know thats not the issue, it moves just fine I've checked. Something electrical is screwed up. I have ordered a replacement sensor for the interior and we'll see if that fixes. If it dosn't any of you have idea's or have experinced this?
#7. Drivers side door lock. Sometimes it locks sometimes it goes down 1/2 way. Sometimes it dosn't unlock unless I hit the unlock on the remote 4-6 times while hitting the doorlock area with my fist. I've already had a new handle put on when my interior one and exterior ones broke off and I was stuck in the truck and had to "dukes of hazard" in and out for a few days. This problem is starting again...Any fixes? This was something I actually let someone fix because I didn't have time to deal with it. It was fixed like 2 years ago.
ummm yeah thats about it.
Thanks guys.
Thanks guys.
