chedderslam
- June 14, 2010
- Mobile, AL
- '97 Eddie Bauer 4wd
1997 Explorer Eddie Bauer V6 SOHC, 110k miles
Driving home from work last week, lose power steering and car over heats all at once. Pull over quickly and see the serpentine belt is off. Closer inspection reveals that my idler pulley has disappeared.
Replace idler pulley, replacing belt as well. Old belt was not destroyed, just figured I would replace it while I was doing all this.
HORRIBLE squeal after starting truck. Thinking that I got a bad replacement pulley, switch it for another one. Still squeals.
Go to autozone, they test alternator and say it is bad. So I replace that, thinking that will fix the squeal. No dice.
Also tried some belt conditioner.
The squeal happens only when:
Do I need to replace my ac clutch/compressor?
- Starting truck, for first few seconds
- Turing on heater, entire time heater is running
