lost key pad entry code | Ford Explorer Forums
flipside
honolulu,hi
2001 explorer sport
lost entry code for key pad on driver door i know it's some where hidden in the vehicle but where? there should be a master code for the vehicle cant find it they say it should be behind the pcm or under passenger side dash behind glove box? havent used entry pad for 5 years would be great if any body knew where it is
it should be on the RAP. its inside the drivers rear quarter panel. if you take the access panel off, you will see a little white box with wires coming out of it. there should be a sticker on that with the code.
i have the same problem i bought it and the guy couldnt remember the code, i checked the back and it was worn out so i said screw it
thnx 4 da info people great web site aloha
so i pulled around on the dash defrost panel and its not budging, i dont want to break it so i figured id come in and see if anyone has any tips on removing it.
