Sweersa
- September 1, 2014
- Marne, MI
- 2005 Ford Explorer XLT
My 2005 V6 4.0 XLT 4x4 today threw a Check Gauge light, and at the same time the oil pressure gauge dropped to the bottom, and the Low Oil Pressure warning was displayed in the message center. After about 30 seconds or so, the dummy lights would go away, oil pressure gauge would go back to the middle position where it normally is, and after about ten or so seconds the oil pressure guage would go back down, dummy lights back on with message center warning of low oil pressure, and the process repeated until I got home. I shut down the engine to check the oil level (seemed fine) and restarted it, it idled fine for the 5 minutes I ran it. I also gave it some gas to increase the RPM while running in park in the driveway and everything seemed ok.
I have just under 300,000 miles on this beast. Last changed the oil 2,400 miles ago (I've always run 5w30 conventional) and the dip stick had oil on it. I plan on changing the oil and filter tomorrow morning. I typically change the oil every 2,500-3,000 miles, as this vehicle has exhibited loud timing chains for years.
It seemed to drive and sound fine (as fine as a 3rd gen Explorer with 300,000 miles) throughout these events.
Any thoughts on what it could be? I realize at this mileage, and age, it could be anything.
