Lower ball joint drivers-side 2000 4wd | Ford Explorer Forums
zhanx
Up state NY
2000 xls
Ok i changed the passenger one no problem. but "bad" one of the two the drivers side refused to come out. i am getting ready to pull the whole d@mn lower arm off and put it in a press... before i do questions :
1. should i take a torch to it.. its thin metal down there and i dont want to make it brittle
2. yes i tried a "rental" tool that didn't work at all its stuck really really good like
or should i just say screw it and pull the lower a-arm and dont it like that..
fyi i am mechnicly inclined but this is kicking the butt, passgener side = easy drivers side = high blood pressure and a need to throw tools
i am leave to head to lousianna (in the army) real soon so i need to get this done so the wife can drive it
and yes i messed up the ball joint enough where the snap ring will not go back in
did you use the right tool to remove the joint? basically a ball joint press looks like a giant C-clamp. If you did, did you use the proper "cups" (or metal cylinders really) to support the A-arm underneath?
some people have also gotten lucky and used a BFH to drive the joint out :hammer:
You'll need to remove the snap ring that hold the ball joint down. Once you removed the snap ring, it should just drop.
Thanks for serving our country, Z.
I think he's already removed that:
ok it looks like its going to the shop. i got time to pack and thats about it. sucks.. i was gonna remove the lower a-arm use heat on it along with the tool but oh well and a BFH wasn't enough this time. cant win them all.
I had a helluva time with mine... I sprayed some Deep Creep on it, let it soak while I did the other side, then beat it somemore with a BFH and finally got mine loose. And yeah, that balljoint press can be a PITA... the one I have (I assume they're all the same?) isn't deep enough, and it was a pain to get it onto the bj.. plus the half-shaft being in the way didn't help (couldn't seem to remove it from the knuckle)
ok i got it changed.. the shop couldn't get it.. tools used :
torch
ball joint press
6 foot breaker bar and 6 foot pipe on it..
time : 2.5 hours..
effort : sweating like a pig
i had to heat it use a press and still had to use a bfg hammer on it.. and it took work. but i got it.. truck drives like a dream with one tire with no weights or sand in it (forgotto put sand in the spare and i rotated it on today)
thats a helluva lot of torque to get a joint out, i think i used a 2 ft breaker bar hooked up to the joint press - nothing more. so u mean that u had about a 10 ft. arm on that press? :eek: the 2000 XLS' musta came with welded in joints ;)
IZwack said:
F.O.R.D : Fix Or Repair Daily
You have this on a FORD website and you own a Ford? Care to enlighten me?
-Drew
well since u ask, sure! well basically it goes like this ok, gather around children, its story time.. ok so here goes.. so i wake up like at 5:45 in the morning right, go to school or work (depending on which day it is).. and when i get home, its time to get back under the explorer, or in the explorer, or somewhere relativvvvvvvvely close to the explorer.. probably within like 3 feet of the explorer, sometimes even 4ft.. in order to fix something.. thats just how it goes.
oh and do pardon us zhanx for hijacking ur thread... i owe u at LEAST one tall glass of lemonade :thumbsup:
my baby(my ranger) needs me and i dont know how to help her
I have a 93 Ford Ranger Splash i have to put a starter in but i don't know correct steps to wiring the starter there are two wires and a plug one wire is round at the end and one has square and i am having trouble locating the ignition switch so that i can swap it out with a new one i bought the book but it isn't helping can someone help and if possible a graph or chart or video if possible thank you
