lower t-case gearing options | Ford Explorer Forums
dkchrist
Fayetteville, AR
93 XLT 4DR
I would like to get lower gearing in my truck. Have 03
sohc 5 speed with electric shift t case BW 1356(is that right or is it 1354)? what can i do for the least money to get lower gearing?
new gear in the axles. The x-fer cases in these are chain drive.
forgot about those haha
will any other t-cases bolt up or does anyone make an adapter for like a rubicon t case?
Just swap in a different tranny if you want to use a rubicon tcase. The ranger uses an oddball 5 bolt 25 spline tcase. They are the only to use it so it is difficult to swap. There is also the stubler but I dont have a link for it. It is much like the Dand D one just about an inch shorter though but twice the cost.
so then no other ford t-case will swap in huh
thanks for the input guys i already have 4.10s and would like to stick with them maybe if i get 33 i will go to 4.56s again thank for the input
Stubler= awsome!!
www.4-x-fab.com
theres also a kit made by D.D. Machine over on Pirate4x4..its cheaper..but you need to do some fab work and source a case to do it...also ALX over at RRORC.COM is using the kit and making drop in kits with them..
check out my thread on the stubler.. :D
