Goober
- May 23, 2000
- Lexington, SC
- '91XLT4x4
I ordered it from JCWhitney and had it within 3 working days as promised. Total cost of $36. After getting home last night, I hooked it up and only had one problem. I guessed the wrong wire for the power in the tailight and got out my handy-dandy Haynes manual and looked it up(brown wire). The ground went to the door strike for the gate. Tested it and buttoned everything back down, works great. I routed it so the only evidence is the black wire from the lightgoing from the trim around the back window to the interior where I put the inverter out of the weather. Ran the wires down to a grommet that enters the side of the tailight housing and hooked it up. The black wire runs right next to the rear defroster wires so you can barely see it. A couple small zip ties and pull the wire to the backside and it is gone.
Easy install, had to enlarge one hole to slip the connector through and route it. About 30 minutes and done.
