masospaghetti
- October 22, 2006
- Huntington Beach, CA
- 98 XLT, OHV, 4D, 4x4, 5M
I recently rebuilt my M5R1 transmission and the shift action from 1-2 is inconsistent, sometimes smooth, sometimes really notchy. 2-3 can be a bit inconsistent as well but not as bad as 1-2.
The hub/slider engages easily for the first half of the throw, but the trouble seems to happen on the 2nd half. I've tried different different fluids, the best seems to be plain Mercon ATF.
I installed all new synchro rings and the hub/slider assemblies are new. The 1-2 hub/slider was a new old stock OE part. 3-4 was a new aftermarket hub/slider. It's been about 1000 miles since the rebuild. I did not replace the gears on the main shaft.
If it matters I have the 2.9 gearset (steeper 1-2-3 gears).
Any suggestions or comments?
Edit: Added some pictures from my endoscope thru the fill plug of the 2nd gear assembly.
