thanks for the info. The PCM had to be reflashed on a VERY cold winter day because the car would not stay running at idle. Once the temp warmed up it stayed running enough to get it to the shop (despite a VERY VERY rough idle at redlights) we sat at the dealership nearly 2 hours, then they came to us, said the PCM had to be reflashed and charged us $250. They said at the time it was not covered under warratny. I did read about this being false, but cannot locate the receipt for this, so thats money down the drain.
there have only been 4 a/c clutches so far, but the one its on now (the 4th one) is making an annoying noise.. its been doing this since mid winter. Its not very loud, only hear it when the windows are down.
In this 5 years I've also had an exhaust header crack, which is to be expected sinc ethis is an extremley common problem with our vehicles.
The transmission is interesting.. I got so frustrated with it I didn't even bother going the 2nd time... ok.. so the transmission was acting up, just like its doing now, I would press the gas and it'd jerk.. let off the gas it'd jerk again, it would shift hard, sometimes take a very long time to shift, and get stuck in what seemed to be neutral between gears.. also at times it would (and it does all this now btw) delay nearly 5 seconds before actually engaging the drive when shifting from say.. reverse to drive, or park to drive. One time I nearly got in a wreck because of such.. I put it in park at a red-light and the guy behind me was in a hurry. Anyway.. I took it in the 1st time with these problems, immediatley they replaced it, it took them a solid week, then it came back with 3 pages of replaced items and a $700 warranty charge (he said it would have cost that much had we not bought the extended warranty) ON THE DRIVE HOME.. it was doing the exact same things.. only not as bad. I told my dad, but he informed me that its in my head and to give it time to break in. Well.. its broke in and its doing all this stuff still.. just as bad if not worse. But its so "intermittant" that they "can't find anything wrong"
