draco880
- August 29, 2006
- Oregon
I have a 94 XLT with about 160k on it, which I got used not long ago. Recently I changed the plugs, oil, oil filter, air filter, and cleaned a bunch of the electrical connections and the IAC valve with no-residue spray. After than, it developed a surging problem and a rough idle, which as it turned out was caused by a line coming off the vacuum tree. This was fixed and a short test-drive went fine.
Most recently, after sitting for about 4-5 days, I went to start it and it had electrical power but couldn't turn over all the way. The next time, it seemed like it had less electrical power, and I heard a rapid, machine-gun sounding noise from under the hood. I popped it open and looked: the suspect hose was still connected to the tree, plug wires looked fine, all the electrical connections I could see were plugged in. Last time i tried it nothing happened, and there was no electrical power.
Here's my hypothesis: the positive battery terminal has some pretty serious, visible corrosion. This could prevent the battery from charging, yes? Is there a way for me to check this before replacing the cable? And does anyone have any advice for this repair?
Thanks in advance for any assistance. Great forum, too, btw.
