Xeek
- March 21, 2010
- Virginia Beach, VA
- 1991 xlt
- tps measured 1.07V closed, smoothly rised to 4.54V at WOT. i turned the idle screw down until closed throttle reached 0.97V. now its 0.97-4.54V nice and smooth.
- new IAC read 0.98 ohms on the sensor itself.
from easyautodiagnostics: The TP Sensor’s connector is BAD, usually the locking tab is broken and the connector has worked itself loose, causing an intermittent false connection.
tps connector has 2 locking clips, one is broken off. other then that, the maf clip is broken, coil pack clip is broken, all 6 injector clips are broken.
ive played with the idle voltage and giggled the clip so maybe itll fix itself now. no idea.
