98EBV8
- November 9, 1999
- Alaska
- 1998 Eddie Bauer V8 AWD
Originally posted by Robert
Ford does not fill the front axle up with synthetic fluid. The rear will only be filled up with sythetic fluid his has a 4.10, limited slip or V8. If Ford didn't put synthetic in the differentials, then the 100K change interval applies. If Ford put in synthetic fluid, the according to Ford it is filled for life unless the axles are submerged in water. I would still change it though.
How can I find out if the axles are filled with synthetic?
About the 100K interval, I read through the Police/Taxi section of the guide. So, it seems that the axles are lubricated for life, unless the axles are submerged in water.
But the guide is not clear on which vehicles have the synthetic lube. It does say that Ford design light-truck axles do have synthetic lube in it.
Here is the information from the 1998 Explorer Service Guide:
"Rear axles containing synthetic lubricant are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected, service required or the axle assembly has been submerged in water. The
axle lubricant should be changed anytime the axle has been submerged in water.
Non-synthetic rear axle lubricants should be replaced every 5,000 km (3,000 miles) or 3 months, whichever occurs first, during extended trailer tow operation above 21 Celsius (70 degrees Fahrenheit) ambient
and wide open throttle for extended periods above 72 km/h (45 mph). The 5,000 km (3,000 mile) lube change interval may be waived if the axle was filled with 75W140 synthetic gear lubricant meeting Ford
specification WSL-M2C192–A, part number F1TZ-19580–B or equivalent.
Add 118 ml (4 oz) of additive friction modifier C8AZ-19B546–A (EST-M2C118–A) or equivalent for complete refill of Traction-Lok rear axles. The rear axles lubricant should be changed anytime the axle has been submerged in water.
Light duty trucks equipped with Ford design front axles are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected, service required or the axle assemble has been submerged
in water. The axle lubricant should be changed anytime the axle has been submerged in water."
