PotatoExplorer
- August 15, 2016
- Location
- USA
- Carlisle, PA
- 2008 Ford Explorer Ltd.
Hey guys,
I've been having some major creaking coming from the front end. I suspect it's from the driver side lower ball joint. It use to be really noticeable when I would turn the steering wheel ever so slightly left/right at a dead stop, but that seems to have dissipated. Now it mainly creaks when I get in/out of the vehicle or when I come to a stop or begin to accelerate (vehicle sinking towards the front when applying brakes and vehicle sinking on the back end when giving gas).
I've been trying to find a detailed video or walk through of how to do this. This weekend I just replaced my 2003 Ford Ranger upper control arm/ball joint and lower ball joint. I had a hell of a time due to rust (and running to Autozone and Lowes for many different sockets) and mainly the new upper ball joint stud resisting going back into the top socket of the spindle/steering knuckle. After 4 some hours of hammering, prying, torching, raising/lowering the steering knuckle and spindle, it turned out it was a combination of a tiny burr and built up road crud on the inside of the spindle socket opening. A round hand file, some elbow grease, some penetrating fluid and a little dab of regular lithium grease solved the problem. But boy did that make me never want to touch another ball joint again.
BUT - I have to replace this one on the Explorer to get rid of this annoying creaking. So I just want to know how similar of a processes is this compared to the 3rd gens?? I saw a 1A Auto video that showed them ripping apart the entire steering assembly - tie rods, sway bars, etc... but for the Ranger I just removed the axle nut, caliper bracket (bracket/pads/rotor) removed and placed onto a support, pulled the cv shaft out and tied it up, removed upper ball joint pinch bolt, lower castle nut and moved the whole knuckle and supported it out of the way.
And I have a feeling that once I'm in there that I should just replace all of the other joints as well? AHHH?!!?! This makes me want to rip my hair out.
Thanks guys!
Thanks guys!
