OneofMany
- December 21, 2012
- Georgia Mountains- Talullah Falls
- 94 expl 4x4
i am not so familiar with these engines...I found a steady stream of coolant spraying the firewall from somewhere around the intake. I found a sensor that seemed loose and took it off only to find it looks like a position sensor. Looking up the part Bosch#0273008002 shows it as a phase sensor. It cant be the cause of my leak, i doesnt seem to be in contact with coolant. However the leak seems to be close to there. I have seen lower intakes leak and by the location of the source it could be that, however i have never seen a stream of coolant spraying out of a a joint between block and intake or intake and cyl. head. I did take the upper intake off in order to get this far. Is there a hose back there i can check b4 i take the lower intake off? I sure as hell do not want to get into the cyl. head on a 230k mile engine.
