marker light and radio issue | Ford Explorer Forums
Exrange
Charlestown, RI
2008 sport trac 4.6 limit
I seem to be having a problem that when i start the car both front marker lights are on- no other lights and my headlight switch is turned off. what i also seem to be having a problem with is my radio will not turn off when the vehicle is shut off and i exit the car out of any door. I checked the harness in the doors because i did have a break in it a year or so ago. they seem to be fine. oh, and its an 02.:rolleyes: Any direction would be greatly appreciated.
Thanks,
Matt
for the radio...check the Accessory Delay Relay.
thanks for the reply, is that part of the headlight switch?
no, it's in the fuse/relay box under the hood. relay 2075 spot K126?
hey thanks a lot, I'll give that a try
